Transmission Noises
Old Feb 28, 2008 | 07:50 AM
rjnewt's Avatar
I came home from work yesterday in my 2002 Sl1 with 85,000 miles and the drive was fine. When I backed my car into the garage I heard a klunk type of noise when I switched from Drive to Reverse. When parked in my garage I then heard a humming type noise from my engine area. Went and got my AutoTap and had a P0706 code appear, (transmission range sensor circuit range). After awhile, the humming went away while I was in Park. I shifted gears and this is what happened.....
From Park to Reverse....Small Hum and then nothing
From Reverse to Nuetral....Continuous Hum
From Nuetral to Drive.... 2 Small Hums and then nothing.
From Drive to 3rd..... Nothing
From 3rd to 2nd..... Continous Hum
Woke up inthe morning and have not heard any humming noise. Transmission problems of some sort...any suggestions????
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old Feb 28, 2008 | 09:35 AM
Low Saturn's Avatar
A loose shaft nut under the end casing can cause the reverse slam. Tightening the nut before the problem gets worse may help the transmission last a few more years.
puckhead
Jun 8, 2010 05:40 PM
Tman_417
Engine & Internal
Oct 9, 2007 03:04 PM
tbenson82
Apr 26, 2007 12:48 AM
clhawkins74
Mar 8, 2007 08:57 AM
lynn
Saturn L300
Sep 12, 2006 02:10 PM
