Trans problem in 1997 SL2...help!
Old Jan 5, 2013 | 05:18 PM
randolphjones's Avatar
Default Trans problem in 1997 SL2...help!
My 1997 saturn is an automatic. I believe it's not going back into first gear because it is slipping gears when I get up past 55/60 mph. When I decelerate, and go back down to around 15 mph until I stop it's a hard shift, and it's running about 2000rpms. I know it's not going back into first gear. Any ideas of what is causing this?
Old Jan 6, 2013 | 07:36 AM
Have you tried a fluid and filter change? That might help it.
Old Jan 6, 2013 | 06:32 PM
Yes, the oil has been changed, the coolant has been flushed. I'm thinking it's a silinoid(sp?)?
Old Jan 7, 2013 | 07:49 AM
If you can get it to a transmission shop, that's what I'd recommend. Ask them if they can check your CVI's. Clutch volume indexes. If they're within spec, then you may just have a solenoid problem. But, I'm not a mechanic, so don't take my word for it, okay?
Old Jan 7, 2013 | 08:44 AM
Good luck with your repairs ....
Old Jan 9, 2013 | 02:27 PM
Mechanic opened it up. He thinks it's the 2nd and 3rd solenoid
noclue
Apr 26, 2011 07:04 PM
PStone
Sep 25, 2009 10:47 AM
jlphillips
May 7, 2008 03:57 PM
tj54020
Oct 27, 2006 02:06 AM
browncitychick
Jan 20, 2006 12:26 PM
