my check engine light has been on for about 4 months now. EVERY car place/tune-up station/oil change station i go to can not run diagnostics on my 94 sl1. I think it may be something serious and i want to get it checked, but im at a loss. anybody know a way to check this thing?
If your light has been on for that long, might be a good idea to stop by your nearest dealership, and have them do it...
I have instructions on my website. Just click the following links: How to display codes Diagnostic code chart Transaxle diagnostic code chart And I''d stay away from the dealer. They''ll grossly overcharge you to do an extremely simple task then not tell you what the actual codes are. Then they''ll want to charge you an outrageous amount of money to fix something which is most likely a simple fix. When you run the codes, I bet you come up with a code 26 or 32. Neither of which are a major problem.Edited by: Low Saturn |
As per usual, LowSaturn manages to come up with an even better idea ... less expensive. Thanks, Mike
| All times are GMT -5. The time now is 09:08 AM. |
