Stalled and won't start
98 Saturn SL2 the transmission had leaking a was going to get more fluid and car just shuts down. Not having any tools pulled the battery terminal to see if maybe something had triggered the shutdown maybe the transmission getting hot and what. It checked all the abuses and release they seem to fine I hear the pump relay is it is doing its job by my knowing the sound of them. I have checked the Schrader valve by the fuel rail and nothing had came out as of gas that I seen not knowing how much pressure they hold assume I would see something at least but nothing. I'll be checking the obvious spark power to the pump. Also telling people the fuel filter to you see if there is blockage. To my understanding there is not a fuel regulator or emergency shut down switch.
Can a BAD ECTS cause a no spark?? Will the car start with it unplugged.
Torque converter clutch stuck On has been a code present before this happened and I knew I was low on trans fluid. Upon taking out my battery to replace it I noticed an wire cut on top of the transmission. Could any of this be culprit to a no spark?
Car has just stalled out with no spark at ECT. There is power and ground there is power to all fuses and relays. With key on I have 5 volt refrance at to MAP TPS EGR. I have changed the CKP. No further test after. Testing under hood fuses again noticed there were 3 fuses that had brighter lights on. Left car and next day I tested all fuses again all were good with 11.9 reading. Before leaving the car again. With key in the on position I have no power at the TRS/LP TRS 3/4 and TRS 2/TCC fuses. What causes this with temperatures in the -0 I don't want to freeze on next tests. I have ordered a ETCM and would love try and diagnose a different problem before putting it on come next Monday if it isn't the culprit.
It's funny not funny how we ask simple questions in an attempt to help you troubleshoot, and you respond by ignoring them / providing no response.
Car has just stalled out w no spark at ECT. ECTM? I'd hope you had no spark there. No clue what that means
3 fuses that had brighter lights on. wth?
11.9 means battery not fully charged but if it can't be started that'll happen.
