speedometer won't work
Old Aug 25, 2009 | 10:22 AM
championapbt's Avatar
Exclamation speedometer won't work
Hi i am new to saturns me and my wife just bought a 1996 Saturn s series sedan and we found that if you turn the heater on the speedometer stops working but once you turn it off it starts working again. So i was wondering if anyone has had a similar problem and if so whats wrong with it and how'd you fix it? Thanks.
Old Aug 26, 2009 | 08:39 PM
wow -- never seen that before... this should be interesting.....
Anything else acting funny/not working on the dash/instrument cluster?
Is it only the heat? Does it behave equally weirdly when you turn on the A/C?
Any other performance problems?
Old Aug 27, 2009 | 10:56 AM
And nope everything still works when that stops and it still works when the AC is on too only when the heater is on is when it messes up.
Old Aug 27, 2009 | 01:07 PM
alright i have been able to make up some more info that may help solve the problem. We have figured out that the speedometer does not work when it is cold out till the car is warmed up we thought it had something to do with the heater at first cause it was cold so we would turn it on so we thought it had something to do with that till today when we started it up and it didn't work and the heater wasn't on. any ideas why the cold is interfering with it?
Old Aug 28, 2009 | 06:52 AM
needle sticking....
Old Aug 28, 2009 | 11:14 AM
gonna check that today when i get a chance.
Old Aug 29, 2009 | 10:11 AM
Load test Alternator
Load test Battery
Check both battery cables.
The positive cable could be corroded inside the wrap at the battery end
Low voltage or amps can cause all sorts of problems
If you see any sign of a past battery leak pull the battery, pull the battery tray and start cleaning and checking the wires under the battery tray.
RaceyRaider3
Jun 11, 2015 04:40 PM
tikidude
Aug 30, 2014 05:04 PM
hofgott
Nov 23, 2013 11:49 AM
PhantomLover007
May 23, 2007 08:41 PM
Gordon Bowden
Dec 20, 2006 10:36 PM
