SL2 Engine
Old Apr 14, 2008 | 02:10 PM
SleeperSaturn99's Avatar
Hello! I am new to this site and had some questions. My wife has a 1999 Saturn SL2 with the 1.9l DOHC twin cam engine. The problem is that about a week ago, the engine seized up. She failed to have the oil change done on it and the motor locked up. I was wondering if there is a better engine that i could but into the car (such as the 2.2 supercharged engine that came in the Ion) or do i have to buy the same engine? And what would be better: rebuild or new engine?
I was also quoated $4300 for a remanufactured engine. Is that too high?
Edited by: sw2cam
Old Apr 14, 2008 | 03:49 PM
Low Saturn's Avatar
You can only use a Saturn 1.9L engine in the car. 1999-2002 will be a direct drop in.
$4300 is outrageous for a rebuilt engine. I've rebuilt Saturn engines for local people and for myself for about half that. If you use the correct parts, a rebuilt engine is superior than a crate motor from Saturn. You can pick and choose the best parts over the 11 years that engine was built.
Old Apr 21, 2008 | 09:29 PM
jayd9631's Avatar
i had a siezed engine in my 96 sl1. i called the local junk yard and bought a used one with 30,000 less miles for 800 bucks. had it installed at a local shop, it took about a week and over all spent 1200. beats a reman, and it sounds quieter to, try it,
lates
JayEdited by: sw2cam
Old Apr 21, 2008 | 09:56 PM
Low Saturn's Avatar
I bought this for $800
Old Apr 24, 2008 | 09:18 PM
^^^^^^^Is that for a 99? That looks just like my wifes engine! Where did you get it from? It looks brand new!Edited by: sw2cam
Old Apr 25, 2008 | 09:07 AM
Low Saturn's Avatar
It will work in a 1993-2002. And it is brand new. I bought it from a local GM parts warehouse that had it listed on craigslist.
Old Apr 27, 2008 | 09:23 AM
What is the engine code so that I can see if i can order it too?
Old Apr 27, 2008 | 10:00 AM
Low Saturn's Avatar
You wont be able to get one at $800. You also wont be able to order it directly from the warehouse. You'll have to get it through your local Saturn parts department. And in that case, the same engine will run about $4800.
Old Apr 28, 2008 | 09:19 AM
Okay. But there seems to be some information that is messed up here. Low Saturn- you said that the engine is for 1993-2002. But earlier in this post you said 1999-2002. Which years am i looking for and what one is the best?
And heres a dumb question. I was told buy the garage that it has a 1.9 DOHC. But the block says Twin Cam. What is the differance if any?
Old Apr 28, 2008 | 09:36 AM
Low Saturn's Avatar
In your case a 1998 or 1999 will be a direct drop in. 1993-2002 will work, but some fuel system components will need to be swapped.
No difference. DOHC stands for Dual (as in two or twin) Over Head Cam.Edited by: Low Saturn
