SL2 Cut off while Driving
Old Nov 27, 2016 | 01:45 PM
Impala1960's Avatar
Default SL2 Cut off while Driving
1998 Saturn SL2 cut off while driving, would not restart. You can hear a relay clicking in the fuse box but not a sound at the starter. Replaced relay still no start. Engine will not turn over Any ideas of where to go from here. Thanks for any help I can get.
Old Nov 27, 2016 | 07:56 PM
I would see if you can turn the engine over by hand, with a wrench on the crank bolt.
Old Nov 28, 2016 | 05:40 AM
I agree with Andy. But the first thing you should do is check and make sure you have oil in the crank case. If you have oil and can turn it by hand, try tapping the starter with a hammer. The bendix might be hanging up on it, if it's a high mileage car with the original starter.
Old Nov 28, 2016 | 01:03 PM
That clicking is the fuel pump relay closing to prime the fuel system, then opening.
So you have at least some current flowing from the battery (meaning only that the battery is still connected.
By all means check your oil and let us know where it is on the dipstick.
Did the OIL dash light come on at any point before it shut off?
jcoll72305
Jan 24, 2013 09:45 AM
skitzo88
Aug 6, 2011 11:42 PM
Junie
Aug 2, 2010 05:09 PM
derin6770
Jul 8, 2010 05:41 PM
cadman33619
Jun 16, 2009 05:46 AM
