Saturn sl2 2002
Old Dec 18, 2014 | 11:20 PM
tonycavaliere's Avatar
Default Saturn sl2 2002
My saturn sl2 2002 will not start, have gasoline, but the score board is in "empty" and the light of booking this ???? lit, check the relay and replace and fusuble tambiem. In the fuse panel cabin has a connector that the "lid" says tester bomb, but not how it works, it's just a hole and apparently has an electrical terminal. when I pass the switch, I hear the pump running. also seems strange that the computer stays "hot". Can someone help me? thank you
Old Dec 19, 2014 | 12:41 AM
no tech questions in the new member area please. Post moved.
Old Dec 19, 2014 | 12:59 AM
Tony -- whatever happened with the ects/cooling fan issue? Did n't see any updates in that thread.
As far as your current post:
I am not trying to be mean, just honest. Your English could use some improvement.
PLEASE describe your problem to a native english speaker, have them write it down, then post it here.
From what I can discern from the above, the car won't start, there is gasoline in the tank (how do you know this?) , but the gas gauge reads empty, some light on the dash is lit but you don't know which one.
You then replaced the fuel pump relay and also the fuel pump fuse. You then depressed the fuel pump test button on the interior junction box and heard the fuel pump run.
I have no idea what "computer stays hot" means.
Also please do not use spansih (like tambiem) in your posts--it just makes things that much more difficult to understand
How old is your battery?
Old Dec 19, 2014 | 02:38 PM
keith's Avatar
I can only answer one question as I don't understand the rest of the post. The computer has a keep alive wire that provides power to its memory. If it looses its memory, then it has to relearn all the drive parameters every time it is started.
This wire is usually shared with the radio so it doesn't forget the presets.
Cdelaney
Jan 24, 2013 10:19 AM
Cdelaney
Jan 19, 2013 10:56 AM
Matty561
Aug 3, 2011 09:20 AM
leenie
Apr 22, 2011 10:00 AM
Jasen101979
Aug 27, 2007 12:34 PM
