Replace front brakes
Old Dec 30, 2006 | 08:08 AM
Neal Z's Avatar
I need help with my 96 SL2. I have to replace the brakes on the front of the car. And I was wondering is there anything special I need to do this? Or how? I had a Subaru before and I changed the brakes on that car. Do you have to turn the pistons in the calipers to get them to move back to accept the new brakes? I'm new to this forum so I sure would appreciate your help. Thanks
Old Dec 30, 2006 | 09:54 AM
No you do not need to turn the pistons.
Old Dec 30, 2006 | 10:27 PM
Neal Z's Avatar
So To change the pads up front, all I have to do is push the plunger back in? Pretty straight forward.
Old Dec 31, 2006 | 04:55 AM
Low Saturn's Avatar
Just use the old pad and a large "C" clamp to push the piston back in. Rotors are $20 each, might as well replace those too since you have everything apart and Saturn rotors are know to warp.
If you have ABS, you have to turn the piston on the rear calipers for it to go down.
Old Dec 31, 2006 | 06:28 PM
Neal Z's Avatar
The car does have ABS and traction control. So what do I have to do different? Thanks
Old Dec 31, 2006 | 08:35 PM
Low Saturn's Avatar
If you're just replacing pads and rotors, then nothing. Just remove and replace like any other car. Just dont try to push in the pistons in the rear calipers.
gregtheo
Aug 15, 2008 11:09 AM
afai
Jul 10, 2008 10:06 AM
AlexT
Feb 9, 2007 10:46 PM
mfunk49
Feb 1, 2007 06:24 PM
brianfgonzalez
Aug 20, 2006 08:38 PM
