Radiator Fan / AC
Old Aug 3, 2008 | 09:55 PM
Koqui's Avatar
Hello
I have a 95 SL2 Doch; in which my fan doesnt turn on automatically, I had to get a work around from the parts store, since the mechanic said that the Computer was not working properly..-Sight- the car runs fine after the work around....Well I went and Bought me the computer for it, and installed it removed the work around and still it didnt work. I replace the relay,motor and sensor, and nothing. I also tried turning on the AC fan and nothing makes the Fan kick on. Any Ideas?
Old Aug 3, 2008 | 10:08 PM
davesl2's Avatar
try fixen up a switch that you can control from inside the car if it doesn''t turn on by straight battery power then get a new fan.
Old Aug 3, 2008 | 10:35 PM
Per the original post, I think he already had that setup installed. He is trying to get it to work properly.
Have you confirmed continuity from the battery through the fuse through the relay to the PCM pin and voltage at the fan motor itself {when the fan should be turning on}?
Sounds like a wiring issue.....
LJ57
Oct 29, 2019 04:51 AM
challenger99
Aug 11, 2009 07:11 PM
kelkay
Jul 19, 2008 04:46 PM
deewain
Aug 20, 2007 01:31 PM
vsa2
Aug 18, 2007 07:51 PM
