Please reccommend a manual !
Old Aug 3, 2009 | 09:29 PM
txguitar's Avatar
Default Please reccommend a manual !
Hey everyone,
I have a '99 SL2 (DOHC-1.9),could someone reccommend a manual , I have a Haynes but there seems to be some problems.I noticed how it explained replacing a valve cover gasket and I know their procedure is wrong after looking at my valve cover.Any suggestions.
Thanks ....
Old Aug 4, 2009 | 02:27 AM
budsjlm's Avatar
im sorry but IMO if you cant replace the valven cover gasket with out a manual you prolly shouldn't be working on your own car but i understand time is tough do what ya gotta do...
Old Aug 4, 2009 | 02:31 AM
budsjlm's Avatar
and i've always like chiltons manuals... and just doubble check that you are looking at DOHC not the SOHC.... and well double check under the hood make sure ur irs what u think it its
Old Aug 4, 2009 | 06:26 AM
problem is that most of the chiltons and haynes available now are summary books for zillions of models. If you're lucky, you might find a 99-02 book that was printed before the end of the S cars...
best manuals are the Saturn Shop Manuals but it's gonna cost ya
Old Aug 4, 2009 | 07:33 AM
txguitar's Avatar
I've changed quite a few valve cover gaskets,but they were a lot more straight forward than the Saturn. The manual that I have is the 99-02,but the pic of the valve cover has completely different type bolts,and yes I'm sure it's a DOHC,that's what it says on the valve cover.There seems to be some confusion over the torque specs, the actual R & R is not a problem.But I have looked at a couple of manuals and they had different torque specs .I'll look around for a Chiltons .
Thanks...
Old Aug 4, 2009 | 09:22 AM
budsjlm's Avatar
tourq specs....for a valve cover.... i just tighten down to where i think its good never had prob...ur on the net google it....if you have an auto zone around you go there they'll tell you..
Old Aug 4, 2009 | 01:37 PM
txguitar's Avatar
Thanks ,that's what I've done on other vehicles,I was just afraid of overtightening,
I'm used to the old cast iron type heads ,not these new aluminun ones.
Thanks again...
Old Aug 4, 2009 | 05:14 PM
overtightening = leakage
determine the correct torque specs and use them
Old Aug 4, 2009 | 06:35 PM
budsjlm's Avatar
For aluminum valve cover
http://www.saturnfans.com/forums/sho...d.php?t=137680
i do belive if you scroll down it should ancer the questions u have
redcannon
Jul 6, 2007 11:50 AM
rafferty
May 18, 2006 01:48 AM
jayrod80
Mar 16, 2006 06:26 PM
ZigZag
Mar 29, 2005 01:06 PM
