Please reccommend a manual !
Hey everyone,
I have a '99 SL2 (DOHC-1.9),could someone reccommend a manual , I have a Haynes but there seems to be some problems.I noticed how it explained replacing a valve cover gasket and I know their procedure is wrong after looking at my valve cover.Any suggestions.
Thanks ....
Thanks ....
problem is that most of the chiltons and haynes available now are summary books for zillions of models. If you're lucky, you might find a 99-02 book that was printed before the end of the S cars...
best manuals are the Saturn Shop Manuals but it's gonna cost ya
I've changed quite a few valve cover gaskets,but they were a lot more straight forward than the Saturn. The manual that I have is the 99-02,but the pic of the valve cover has completely different type bolts,and yes I'm sure it's a DOHC,that's what it says on the valve cover.There seems to be some confusion over the torque specs, the actual R & R is not a problem.But I have looked at a couple of manuals and they had different torque specs .I'll look around for a Chiltons .
Thanks...
Thanks...
tourq specs....for a valve cover.... i just tighten down to where i think its good never had prob...ur on the net google it....if you have an auto zone around you go there they'll tell you..
For aluminum valve cover
http://www.saturnfans.com/forums/sho...d.php?t=137680
i do belive if you scroll down it should ancer the questions u have
rafferty
May 18, 2006 01:48 AM
