oil mixing with antifreeze?
Old Nov 3, 2010 | 09:07 PM
skorger's Avatar
Default oil mixing with antifreeze?
i have a 1994 saturn SL1 and it i keep finding oil mixed in with the antifreeze yet no leaks and no loss of oil from the engine, and cuases serious bogs while driving, suggestions please.
Old Nov 3, 2010 | 09:23 PM
blown head gasket or cracked/porous head. if oil is in with the antifreeze, there is likely antifreeze in with oil -- it will be milkshakey. Level will seem fine but things are definitely not well
Old Nov 3, 2010 | 09:24 PM
skorger's Avatar
possible cost of fix?
Old Nov 3, 2010 | 09:29 PM
maybe $700 for a head gasket
head from junkyard engine -- not sure -- check the net
if head gasket ---compression test will localize problem to one or more cylinders
if crack in head or head is porous, may be more difficult to locate
Old Nov 3, 2010 | 09:32 PM
Hmmmmm --
If it's a head gasket, probably about $325usd. If the head is cracked, probably about $525usd. You can save a portion of that if you do the work yourself, but I don't know your level of expertise ....
Old Nov 3, 2010 | 09:37 PM
thanks for the financial corrective action, OA
Old Nov 3, 2010 | 09:39 PM
Hey - no problem .... we do things more inexpensively here in the South
95supersaturn
Jan 14, 2007 01:17 PM
henrylford
Sep 17, 2006 04:58 AM
