No reverse
Old Dec 3, 2018 | 12:10 PM
Wallboss's Avatar
Default No reverse
I just lost reverse gear in my 2002 sl2 automatic without warning! No slam, no noise. How can I tell if I need a valve body or need to replace the input shaft nut?
Old Dec 3, 2018 | 12:19 PM
How many miles on car?
Does 2md gear act normally?
What is the fluid level?
Reverse requires a higher line pressure in the transmission to engage than the forward gears,
Old Dec 3, 2018 | 12:38 PM
Wallboss's Avatar
Default No reverse
110000 miles, fluid level good, 2nd gear seems fine
Old Dec 4, 2018 | 07:05 AM
Does the vehicle shift hard ("slam" ) into any gear and if it does /did, did it slam into reverse?
Old Dec 4, 2018 | 08:19 AM
Wallboss's Avatar
Default No reverse
Never slammed ,always smooth
Old Dec 5, 2018 | 10:53 PM
Sorry for the delay.
See
https://www.sonnax.com/tech_resources/289-saturn-taat-reverse-issues-should-you-replace-the-valve-body
for a nice explanation of scenarios which result in a no reverse condition. In summary, I'd get a quality rebuilt valve body, a new input shaft nut, but check the VSS first. If you drive it long enough you will eventually need both the valve body and nut. I would take the plunge now if the VSS checks out ok since the parts may not be available when you need them later.
Old Dec 6, 2018 | 10:23 AM
Wallboss's Avatar
Default No reverse
Thanks for the input! I was thinking I’d probably do both, but not if there was an obvious choice. It’s been a great little car and I’d hate to get rid of it. My kids have all learned to drive in it and my youngest is almost 16!
Thanks again!
Old Dec 9, 2018 | 09:11 AM
jamnar's Avatar
Suddenly losing reverse in these transmissions (TAAT MP6, MP7 - these are the ones used in the S series) is most likely going to be the result of a failure of the solenoid valve that controls reverse. A gradual failure could be the valve itself wearing out (valve body) but a sudden failure is going to be electrical meaning either the solenoid isn't getting power (broken wire or corroded connector) or the solenoid itself is either shorted or has a broken winding. It's common for people to go with conventional wisdom and use stop-slip or try the "reverse slam fix" but this is normally a problem that will only be corrected by physically replacing or repairing the faulty part. Fortunately these issues are relatively easy to fix and don't require pulling the transmission or insane acrobatics. If the transmission is allowed to slam into gear though, the input shaft nut WILL work loose sooner rather than later and that will be harder to fix and require a special socket and bracket but still be fixed without pulling the transmission. A sign of the input shaft nut working loose is having no 2nd gear. That's why when someone says they lost reverse the first questions after "got proper amount of correct fluid?" are was it slamming and did you also lose 2nd gear.
That Sonnax link Derf gave you is an excellent source of information and parts on these transmissions. I highly recommend checking them out even if you don't plan on buying anything from them. I fixed my transmission with used parts sourced locally using knowledge gained from their site and this site: Saturn S-Series Transmission Repair Kit - CarSaturn
Old Dec 26, 2018 | 05:04 PM
Wallboss's Avatar
Default No reverse
​​​Got past Christmas! Now l can get back to my project!
Test drove my sl2 today and ,somewhat surprisingly, no 2nd gear either. So does that mean it’s a loose nut? Seems like that’s what I’ve been reading.
Old Dec 30, 2018 | 03:35 PM
Wallboss's Avatar
Default Now what?
Now I’ve taken the trans cover off and inspected the clutch pack but it seems like the nut is not at all loose! Now what? I watched a YouTube video where it showed the clutch pack wiggly loose, mine doesn’t move a bit!
