New Clutch on SL1
Old Dec 3, 2008 | 04:42 PM
48builder's Avatar
Hey there. I''''m new here. I recently bought a 95 SL1 and I absolutely love it! I paid 900 bucks for it. It has new tires, struts, and brakes. I bought it from a co-worker and he was the original owner. The only thing that has not been replaced is the clutch. I have a repair book and I see that you must remove the engine to replace the clutch. I do my own maintenance on all my cars (my name, 48builder refers to a 48 Chevy street Rod I am building).
I''''m looking for any guidance I can find on doing the clutch. I may end up paying to have it done, but I figure I can save $500 or more if I do it. I have a tools, a heated garage and a cherry picker, so no problems there. The clutch seems to be OK so far, but I''''m sure it won''''t last forever.
Thanks!
Walt
Edited by: 48builder
Old Dec 4, 2008 | 09:19 AM
Low Saturn's Avatar
Why do you think the clutch need replacing? How many miles are on the car? I''ve seen them last over 300,000 miles.
Old Dec 4, 2008 | 11:45 AM
48builder's Avatar
I don''t, yet. It has the original clutch and I don''t know how long they normally last. Good to know that they can last that long. I don''t want to replace it unless it needs it, but I also travel a lot and don''t want to get stuck somewhere.
What symptoms would indicate that the clutch is on it''s way out?
Thanks,
Walt
Old Dec 4, 2008 | 11:58 AM
Low Saturn's Avatar
Slipping and just not grabbing like it should. And more often than not, the clutch hydrolics go out before the clutch hardware.
Old Dec 4, 2008 | 12:01 PM
There are several indications that a clutch has failed, or is in the process of going bad:
1) Pedal travels to the floor - no pressure or very little resistance; 2)Unable to select/shift gears;3) Clutch slips (engine speed increases with no increase in car speed); 4) Grabbing (chattering) when clutch is engaged; 5) Transaxle rattling or clicking; 6) Unusual noise in or around the clutch housing; 7) Clutch pedal stays on the floor; 8) Clutch pedal very hard to depress.
Edited by: OceanArcher
Old Dec 4, 2008 | 12:17 PM
Low Saturn's Avatar
But keep in mind #1,2, and 7 can indicate bad hydrolics too.
joma1993
Nov 13, 2014 05:56 PM
dustwolf
Sep 26, 2008 12:30 PM
2000saturnsl2
Mar 16, 2008 04:28 PM
squarebush
Feb 1, 2008 07:50 PM
90roadsterman
Apr 9, 2007 02:44 AM
