Need help, egr valve problems
My car boggs at 1500 to 2000
rpms, it is really annoying now when releasing the clutch when I am in
first gear to get going it boggs..
think it is the EGR valve doing this, when I raise the idle it boggs
but when I disconnect the vacuum line from the EGR it is fine. And when
I raise the idle with the hose disconnected it is fine but when I
connect the hose while the idle is up, it boggs and runs rough..I tried
this with another EGR valve I got from the junkyard and does the same
thing, I cleaned out both EGR valves and the diaphram moves and down. I
also replaced the EGR solenoid. There is vacuum from the solenoid when
I raise the throttle, so the solenoid is good.Is my EGR valve
bad? I do not see how the valve can be bad, is there something internal
that could be bad? The diaphram moves easy, so I think it is good, but
when it is on the car connected it boggs at 1500 rpms..I just do not
want to buy a new EGR valve and the bogging still happens..Driving the
car like this is really annoying..What do you guys think?
Edited by: sw2cam
Before buying a new egr concider that the problem might not be the valuve itself. could be senosrs sending bad info to the computer. hook up a reader (or go to auto zone and let them do it) check the code erors. itcould be the ects sonsor or somthin simple.
