Need help - 2000 SL1 running rich P0172
Old Sep 14, 2008 | 12:01 PM
john33's Avatar
I am new to the forum but have been a Saturn owner for a few years. I have a 2000 SOHC SL1 that has 140K on the body. I replaced the engine 2 weeks ago with one from a reputable yard that claimed it had only 22,305 miles on it. It looked like it to. Anyways I replaced the old engine because it was going through 1 quart of oil every 300 miles.
Long story short the old engine was running ragged and the check engine light stayed on. I replaced the engine with the low mileage one and it came with all new sensors, etc... The new engine started off running awesome but after if got hot it would start spitting and sputtering in low RPM''s. I researched the forum here and replaced the coolant temp sensor and both O2 sensors. I also purchased and replaced the fuel injectors and thermostat. The car also has brand new plugs and wires. It still runs rough and throws a code P0172 which is bank 1 is too rich. Im running out of ideas on this one. Is there something else I could be overlooking?
Any help would be greatly appreciated.
Old Sep 15, 2008 | 09:45 AM
TheEngineer's Avatar
sounds like a possible air leak or a bad air flow sensor. Because if you are running rich and its sputtering that bad then is must be either getting a faulty intake air flow reading or it is loosing air comming in through a leak. Possibly in the intake piping or manifold area. Check the gaskets on the manifold as well
Old Sep 18, 2008 | 02:08 PM
slslow's Avatar
it could be any of these
<div align="left">
<table border="0">
<t>
<tr>
<td valign="top">•</td>
<td valign="top">Fuel pressure high</td></tr></t></table></div>
<div align="left">
<table border="0">
<t>
<tr>
<td valign="top">Fuel injectors leaking</td></tr></t></table></div>
<div align="left">
<table border="0">
<t>
<tr>
<td valign="top">O2S-1 contaminated</td></tr></t></table></div>
<div align="left">
<table border="0">
<t>
<tr>
<td valign="top">Vacuum leak around MAP sensor</td></tr></t></table></div>
<div align="left">
<table border="0">
<t>
<tr>
<td valign="top">EGR valve stuck open</td></tr></t></table></div>
<div align="left">
<table border="0">
<t>
<tr>
<td valign="top">EVAP purge solenoid stuck open</td></tr></t></table></div>
<div align="left">
<table border="0">
<t>
<tr>
<td valign="top">Restricted exhaust or restricted air induction</td></tr></t></table></div>
Old Sep 25, 2010 | 06:27 PM
calvintanner's Avatar
Hi there
I have the same problem with my 2001 SL1. Am ancious to hear how yours turnes out. WIll keep you informed If I find the answer. I had a severe bucking problem last year and it was a pluged cat converter. My spitting problem like yours started this spring/early summer.
Calvin
goatsuace
Jan 29, 2015 10:04 PM
rm2011
May 10, 2013 12:24 PM
tfg11199
Oct 17, 2009 09:44 PM
saturmham
May 29, 2009 10:45 AM
jillowolf
Jan 14, 2006 08:51 AM
