Mysterious bolt sitting disconnected on subframe...
Old Sep 16, 2024 | 02:49 PM
Gunnar's Avatar
Default Mysterious bolt sitting disconnected on subframe...
So I took off the plastic shield on driver front side in order to inspect tran mount. (Yea... the rubber is all cracked)
But somsthing very curious. Sitting on the subframe I this long skinny bolt with a large washer, and a nut also not attached. Not sure how it has stayed there!
Appears to be:
M6 x 1 x 30 , with a 10mm head
Any idea where it might go to? I'm very curious if maybea mechanic a decade ago forgot to put a bolt back in somewhere lol
Old Sep 16, 2024 | 04:07 PM
That would be a body or trim bolt. Probably got dropped and didn’t hit the floor. I don’t bother looking very long for dropped bolts.
Old Sep 16, 2024 | 06:15 PM
grcauto8453's Avatar
That's been there a while. Probably a splash shield bolt,
Old Sep 16, 2024 | 09:40 PM
Indeed, that is one of the bolts used to hold on the wheel well/shield, I believe around the front outer edge. Compare it to the ones you removed to get to that spot and I'm betting they are the same.
As for the nut, that looks like a size of nut used on the battery hold down rods on either side of the battery that pass through the hold down cross piece.
The battery hold down rod closest to the left front fender actually needs to be accessed from inside the wheel well. It may very well be the nut that's supposed to be on the end of that other end of the rod.
Old Sep 18, 2024 | 09:53 AM
onlinebiker's Avatar
It' s pretty common to find loose nuts and bolts.
My favorite find was a 3 inch blade Spyderco knife.... Somebody cried when they lost this one...
tweakweak
Aug 11, 2024 11:52 AM
Clapped.out.ion.9
Apr 20, 2023 08:48 AM
wireyourworld
Jan 21, 2009 01:07 PM
erriic1977
Nov 21, 2008 11:08 AM
jisham
Dec 12, 2006 12:14 AM
