Low Oil pressure
Old May 18, 2009 | 07:55 PM
kuhnphil66's Avatar
Default Low Oil pressure
We have a 1997 Saturn SL2 with 114000 miles on it. We have done regular maintenance on it and have had no problems. Recently, the engine races for a few seconds upon starting it up, and the oil pressure gauge stays on for 10 seconds or so. I check it regularly, and it stays on Full.
We took it to a mechanic, who said the engine was junk and needed replaced. He said the main seals were probably bad. Anyone else have any other experiences with this? I can't believe that an new oil pump or a sensor would not fix the problem. No problems, keep the oil changed every 3000 and then Bam! New engine?!
Old May 18, 2009 | 08:48 PM
I don't believe I would trust the DixieHywayBaitShop&AutoRepair to tell me whats probably, maybe, could be wrong with my SATURN. Only one place knows SATURN S-CARS, only one.
Old May 18, 2009 | 08:51 PM
I'd check the oil pressure sensor for proper operation first - or maybe just replace the durn thing ....
Old May 19, 2009 | 07:35 AM
kuhnphil66's Avatar
Default low oil pressure
Thanks, I just may have the Saturn dealer check it out for a 2nd opinion. It does rev for a few seconds upon starting it up, could the oil pump not working properly do that too?
Old May 19, 2009 | 11:27 PM
if the oil is full the main seals are likely fine.
if the engine runs fine it is likely not trashed (no clanking/knocking/thunking)
test and replace oil sender (as appropriate)
If you truly do not have sufficient oil pressure for 10 seconds at every startup, you will quickly damage your engine -- so address this ASAP if you want to ensure the continued existence of your engine.
And stay away from bobsnosehairlaserremovaloutlet&autorepair, as they are not saturn experts
Old May 21, 2009 | 10:41 PM
turbokid's Avatar
Put a manual gauge on to confirm oil pressure is accurate via factory gauge
cadman33619
Sep 2, 2012 06:49 AM
bewigton
Jun 11, 2011 12:02 PM
jlannigan
Jul 21, 2009 04:11 PM
FranconiaFriend
Apr 27, 2009 09:45 PM
Thomas123
Dec 10, 2008 03:43 PM
