Interchangeability of 2000 SL2 window parts
Old May 23, 2024 | 12:52 PM
cade's Avatar
Default Interchangeability of 2000 SL2 window parts
Is there a thread here listing the S-series interchangeability of window parts? My front driver and rear passenger windows are shot. front passenger is dying too.
I replaced my driver regulator/motor with one I ordered from amazon, which only lasted some 6 months, which after poking around on here and learning about the cheapsh*t aftermarket stuff, I regret not just replacing the motor on.
Thanks,
Cade
Old May 24, 2024 | 06:41 AM
2000 to 2002 SL1 and SL2 are likely to fit. Same generation.
.to confirm, Go to www.gmpartsdirect.com and search 2000 SL2 to determine the part numbers for each door.
If you're lucky, The site you are on will have a fitment guide near the bottom. If not, once you get the info for 2000, search for the same part by name and 2001 and see what part numbers come up. Same for 2002. Do not assume anything.
Old Jul 8, 2024 | 03:15 AM
axkoa's Avatar
A quick side note, when removing the door handle, take the electronic door lock out first and you can get to that bottom white pin a lot easier.
192.168.100.1 192.168.1.1
Zaney
May 23, 2018 04:32 PM
RKelly5327
Saturn L300
15
Aug 12, 2015 12:18 AM
Allseasonrider
Jun 17, 2013 10:15 PM
jokool736
Feb 20, 2010 01:25 PM
Tripyr
Jun 17, 2008 07:32 PM
