instrument panel lightbulbs
Old May 17, 2008 | 11:24 PM
irvq's Avatar
Hi all, anybody know what size bulbs are for a 99 SL1 instrument panel and if so are they readily available? Thanking all in advance, regards, Irv
Old May 19, 2008 | 05:04 PM
satty_kingsb's Avatar
Heres the site man, that will tell you what kind of bulbs you need but just to let you know changing the light bulbs in the instrument panels is going to be a pain in the *** [img]smileys/smiley7.gif[/img] .. i tried to change my bulbs to a led blue and had to take the whole damn dash out and messed up my spedo because the saturn cluster is so senative to take out so i said forget it but heres the site..
http://www.sylvania.com/ConsumerProd...otiveLighting/ LampReplacementGuide/AutoLRG-Results.htm
Old May 21, 2008 | 10:36 AM
Low Saturn's Avatar
The clusters are pretty easy to get out. I have instructions on my website. Just pick up the needed bulbs at your local parts department.
1991-1994:
http://www.differentracing.com/tech_...1-94cluster.ht ml
1995-1999:
http://www.differentracing.com/tech_...5-99cluster.ht ml
2000-2002:
http://www.differentracing.com/tech_...0-02cluster.ht ml
Old Jun 6, 2008 | 12:28 PM
irvq's Avatar
Belated response ... Thank-you, it''ll be a great help because it''s bugging the poop out of me, regards, Irv
Old Jun 10, 2008 | 03:32 PM
jisnut's Avatar
yeah be careful taking out the gauge cluster. My thumb got sliced wide open taking the wire off of it. but you should be able to get the bulbs at like advanced auto. thats were i got mine and i have a 98 so might not be too different.
Old Aug 18, 2008 | 01:29 AM
aairwalks's Avatar
There is no reason to take off the stearing wheel and the dash board. If you pull the clips off above the stearing wheel and pull the black plastic that goes around the cluster and radio that is all is needed to access the cluster bolts. the swap should take less than 30 min.
Old Aug 18, 2008 | 09:09 AM
Low Saturn's Avatar
What year are you talking about?
anndruu12
Feb 5, 2011 04:00 PM
john doe
Jan 4, 2011 03:24 PM
snapprhead
Jan 25, 2008 07:38 PM
2timeowner
Jun 4, 2007 09:27 PM
AwolRJ
Mar 4, 2007 01:31 PM
