idil code 49 or idle code 49
Old Feb 23, 2011 | 04:48 PM
james clark's Avatar
Default idil code 49 or idle code 49
1994 sl runs fine but just once in a blue moon when you come up to stop the car well idil up to ab 1100+ and come down then check engine light well come on.code 49 but have check for vacuum leak and only place it seems to idil up at is a black housing on back of carb with 3 lines going to it.what is that?and if that was bad should it do it all the time?(light goes out after you turn car off and start back up)
1.have put new temp sensor in and connecter
2.new muffler
?could converter be clogged up b/c some times i smell a egg smell
Old Feb 23, 2011 | 05:44 PM
Code 49 does suggest a vacuum leak. May be a crack in the plastic housing
Old Feb 23, 2011 | 06:29 PM
why would it only do it some times? whats the name of the housing?
how do i check converter?should i check it i only smell that egg sometimes.
Old Feb 23, 2011 | 08:13 PM
Why would you post this in the new member area? Moved for a reason, next time deleted.
Old Feb 23, 2011 | 09:24 PM
<<only place it seems to idil up at is a black housing on back of carb with 3 lines going to it.what is that?>>
your car has no carb so I have no idea what you're talking about
Post a picture
cloudsplitter8
Aug 24, 2012 07:47 PM
aluminum360
May 8, 2008 02:17 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
