idil code 49 or idle code 49
1994 sl runs fine but just once in a blue moon when you come up to stop the car well idil up to ab 1100+ and come down then check engine light well come on.code 49 but have check for vacuum leak and only place it seems to idil up at is a black housing on back of carb with 3 lines going to it.what is that?and if that was bad should it do it all the time?
(light goes out after you turn car off and start back up)
1.have put new temp sensor in and connecter
2.new muffler
?could converter be clogged up b/c some times i smell a egg smell
(light goes out after you turn car off and start back up)1.have put new temp sensor in and connecter
2.new muffler
<<only place it seems to idil up at is a black housing on back of carb with 3 lines going to it.what is that?>>
your car has no carb so I have no idea what you're talking about
Post a picture
Post a picture
cloudsplitter8
Aug 24, 2012 07:47 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
