High Idle Problem
Old Jun 29, 2013 | 03:31 AM
jrg89's Avatar
Default High Idle Problem
Ok I have a 94 SL, which if I keep the AC on keeps my Idle down to the normal Range 600-700 RPM, if I turn the off the AC I will get a High idle after driving up 1100 RPM for a few secs which will throw on the CEL. I have changed my TPS Sensor, Any Ideas?
Old Jun 29, 2013 | 08:16 AM
Do you get any codes from the OBD system, or is the CEL the only indicator?
Check for a vacuum leak around the intake.
Old Jun 29, 2013 | 03:19 PM
keith's Avatar
To clarify Rubehayseed, spray something like a carburetor cleaner or even WD-40 around the intake manifold gasket, especially around the #1 cylinder and see if it affects the idle. The intake manifold gaskets are prone to getting sucked in at the #1 intake port because it is not well supported and it only has three bolts around the port instead of four as the other cylinders do.
Old Jun 30, 2013 | 07:33 PM
jrg89's Avatar
Ocean- CEL, it is OBD I so 34 flashes if i remember correctly, and it was just saying high idle
Ruby and Kieth, do you have a picture of where this would be. Every time I search online I just find stuff for the SL2 engine DOHC
Old Jun 30, 2013 | 08:14 PM
Cly number 1 of your intake manifold. If you need a "picture" you may need someone helping or doing it for you.
Old Jun 30, 2013 | 09:34 PM
Sounds like a possible bad connection between the ECM and the MAP sensor, or the MAP sensor itself may be defective ...
Heaton4
Oct 15, 2013 09:54 PM
99 SC1 Silver
Feb 28, 2013 06:47 PM
cloudsplitter8
Aug 24, 2012 07:47 PM
x86guru
Jun 17, 2006 04:24 PM
Robkevin
Mar 11, 2006 02:52 AM
