Help with Engine code 26
Old Mar 23, 2010 | 01:00 AM
Curly's Avatar
Default Help with Engine code 26
OK, so my cars SES light has been turning on after a few seconds of driving so I borrowed the Innova 3123 from a friend and checked the computer for codes. I looked it up and it's telling the that Code 26 is
Quad driver circuit
Throttle switch shorted
I have no clue what this means. The car seems to be running fine except for on start up it seems to hesitate a little but then the RPMs slowly climb to normal idle and after that it drives normal. Any how I've looked up as much as I can but these electrical diagrams confuse the hell out me. anyone able to help me out.
BTW it's a 94 SL2 5 speed
Old Apr 4, 2010 | 06:02 PM
Curly's Avatar
So I have found a flow chart that is some what helpful but I don't know what and ALDL is. Anyone here able to shed some light on what the ALDL is?
BTW, I am trying to follow the flow chart in the following link.
http://www.saturnwiki.net/index.php/...r_Output_Fault
Also there is a new symptom. Car is hard as hell to get started up. ESPECIALLY when it has not run in a few hours and its cold out.
Old Apr 4, 2010 | 06:28 PM
saturnsdn's Avatar
ALDL=assembly line data link. if you know how to pull the codes your sticking the paper clip or whatever your using in the ALDL to flash the codes
codyj88
Jan 7, 2013 02:06 PM
james clark
Feb 23, 2011 09:24 PM
bigdezy419
Aug 8, 2008 11:22 PM
Mike1288
May 23, 2008 04:32 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
