Hello
I changed the battery in my 2001 sl1 a few weeks ago and it has been working great! However, I went to start it yesterday and when you turn the key nothing happens, the dash doesn't light up or snything and it won't even "click" the starter. I am wondering what is going on? Thanks.
Hmmm -- could be a bad (not clean/tight) connection between your new battery and the cables.
Also, the main battery cables could be internally failing. Battery acid will sometimes get under the cable insulation, and eat the cables up from the inside (like termites). Are the cables flexible, or do they "crunch" when you bend them? If the crunch, replace 'em.
