heat/radiator Idiot light flashing
Old Aug 7, 2010 | 10:25 AM
Moorecd's Avatar
Default heat/radiator Idiot light flashing
I've got a 98 SL1 1.9 single overhead with the heat/radiator Idiot light flashing and yet the temp gage is running cool. This just happened so I have not opened the radiator/overflow cap to see if fluid is low nor do I have an owners manual to read why it is flashing vs being on solid. When I lifted the hood nothing was boiling and the motor was not steaming hot. Could this be just a low fluid level warning?
Thanks,
moorecd
Old Aug 7, 2010 | 10:38 AM
there is a sensor at the bottom of the reservoir tank that can get fouled and indicate that the coolant level is low -- sometimes you can take the tank off and clean it out with the sensor in it -- sometimes a new sensor is your fix
please do not double post
Old Aug 7, 2010 | 11:23 AM
Derf is on the beam again ---> +1 for that bit of advice
jonnyghost
Jan 26, 2010 08:26 AM
jblckwd
Saturn L300
13
Apr 16, 2009 11:07 AM
coconutprincess
Mar 22, 2007 10:52 PM
dec29p
Jun 18, 2006 06:37 PM
donclaypool
Engine & Internal
Jan 31, 2006 10:16 PM
