gas smell
Old Feb 23, 2009 | 12:23 AM
dtone90's Avatar
why does my engine smell like gas when i start it
Old Feb 23, 2009 | 08:11 AM
Check your fuel lines and make sure you do not have a loose fitting or damaged line. Fuel spraying around in an engine compartment is a definite hazard ...
Old Feb 23, 2009 | 08:54 AM
When you find the fuel leak then you will know.
Old Feb 24, 2009 | 07:05 AM
Because you still haven''''t changed your ECTS like we''''ve advised, so your car is running richer than hell (with a fuel mix equivalent to that used when it''''s about -40 outside), since you said you disconnected the known\bad ECTS sensor...
If you''''re gonna ask for advice and then not follow it, please stop asking questionsEdited by: derf
jwngr
Dec 23, 2013 10:20 AM
Bobthetechguy
Jan 7, 2013 08:43 AM
daisy_payne
Feb 6, 2007 12:13 AM
95Saturn
Jan 9, 2006 03:18 PM
dannyy72
Nov 27, 2005 02:19 PM
