a few problems
Old Mar 25, 2010 | 08:20 AM
one54ton's Avatar
Default a few problems
first off i can hear the belts in the trans chirping when going into 2nd gear. im about to change the trans fluid, any suggestions for better shifts? 2nd the car is hard to start. i dont get many cranks and i constantly have to give it gas in order to turn over. im thinking battery? i put new a new fuel fliter on 1 year ago. thanks guys
Old Mar 25, 2010 | 11:56 AM
If you can hear things slipping and chirping in the transmission than the odds are transmission fix it in a can won't do much more functionally than remove money from your wallet.
Although I have had succuess with LUCAS Transmission additive.
If you can't get many cranks cause your battery is close to dead, than a new battery might be the right solution. Then again the starter motor could be suffering frm the kiss of death. The battery is cheaper and easier to replace.
I have no idea what giving it gas has to do with increasing cranks, it's been my understanding that with a fuel injected car, pounding on the gas pedal is an excersise in futility doing little more than relieving frustration that the car won't start.
As far as the paint comming off, well yuh! It's 17 years old. I have about 100 hours and $500.00 in materials repainting mine 1995 Black Gold.
Old Mar 25, 2010 | 12:36 PM
holding pedal to the floor relieves flooding condition. Are you flooring it or holding it part of the way down.
check pos battery cable for tightness and corrosion
+1 battery first
if you have never replaced ECTS and connector, do so now.
Old Mar 26, 2010 | 08:16 AM
one54ton's Avatar
im holding the pedal halfway down. i think i will take the car to get the battery tested this weekend.
Old Mar 29, 2010 | 08:21 AM
one54ton's Avatar
Also, I hear changing the trans fluid is like an oil change on these cars, this true?
Old Mar 29, 2010 | 08:34 AM
The filter for the transmission is a spin on oil filter similar to the oil filter for the engine.
Fram ffp6646
AC Delco ACTF298
Draining the oil will have to be dealt with seperatly.
Old Mar 29, 2010 | 01:19 PM
one54ton's Avatar
I'm assuming the pan needs to be dropped as usual
Old Mar 29, 2010 | 03:44 PM
results of battery check?
Old Mar 29, 2010 | 05:27 PM
My service literature says it has a drain plug. I have not looked at my 94 to verify or not but it is not going to hurt to look for one. Even if it does, the torque converter will not have one so it can not be drained. An alternative is there are machines now that can be installed in the transmission lines that drain and re-fill as the transmission is run completly flushing the lines and the torque converter. General cost around $75.00 to $100.00 or so for servicing OR don't worry about it and just drain and refill what you have and change the filter.
Old Mar 30, 2010 | 08:09 AM
one54ton's Avatar
havent had time to check the bettery yet. i will try and do it today
