Fault code P0711
Old Oct 19, 2008 | 12:25 AM
goldendd's Avatar
This has something to do with the transmissions. Can it be fixed easily?
When I got this code my 1996 SL1 started running bad. Is there a connection.
Old Oct 19, 2008 | 09:10 AM
Well my booklists the following:
P0711 ...Transmission Fluid Temperature (TFT) Sensor Circuit Range/Performance Error
Sounds to me like you have a temperature sensor that has gone bad, or that the wiring for it is defective.
This sensor feeds directly to the section of thePowertrain Control Module (PCM)controlling shifting mode and performance, so it is quite likely that the two issues are related.
james clark
Feb 23, 2011 09:24 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
Fireball69
Jan 31, 2006 02:09 PM
