DIY resinator replacement
This seems to be a common acurance for us SL owners from what i here ... so this is for the diyers out there
I did this becuase mine is rusted out and a replacement cost anywhere from $72 to $224
what you will need:
1: 2in inlet/outlet 30in long cherry bomb
or 2in inlet/outlet 30in long peice of pipe
1: 2in outside diamter to 1 3/4 in inside diamiter reducer
if not welding in
2: 2in exhaust clamp
1: 1 3/4 exhausr clamp
14mm socket (may vary)
ratchet
jack
jack stands or lift
hacksaw,exhaust pipe cutter, sawzall, cutting wheel, somthin to cut the exhaust with....
Step1: put on lift and raise or jack up the car and put on jack stands(as high as safely possible)(4 will make this easier too)
Step2: locate rusted resinator
Step3: cut out rusted res
(cut close to the end of the res)
Step4: put adapter onto back part of the exhaust..
Step 5: put bomb/pipe onto adapter
Step6: put bomb/pipe on to pipe (cat side)
Step7: weld or tighten exhaust clams
Step8: fire it up and hear your result
I did mine today with the cherry bomb u cant tell the difference from stock...
on a side note:strait peice of pipe will be somewhat louder... when i called the dealer to get a price on the parts they even said instead of spending $224 on it from them what i can do is stick a peice of pipe in there only dif is it will be a little louder
what you will need:
if not welding in
ratchet
jack
jack stands or lift
Last edited by budsjlm; Jul 9, 2009 at 12:52 PM. Reason: making one post....from like 5
O another side note only differance between the stock resinator and the cherry bomb is that the baffling inside of the stock resinator sticks out further into the exhaust flow
cparsels
Oct 6, 2015 11:25 PM
