cylinder 4 misfire
Old Mar 7, 2006 | 12:41 AM
rchinny's Avatar
my 2002 sl2 is reading a cyl. 4 misfire. After some trial and error i believe it is the injector. i am going to change it. has any one had this problem,is it common in this car, or does anyone have any ideas. the car has 64,000 miles.
Old Mar 7, 2006 | 01:15 AM
Chinny,
Check these first:
1) Plugs
2) Wires
3) Corrosion on posts of coils (clean with emory cloth)
How bad is the "miss"? Does it idle roughly? Accelerate roughly?
Does it go away after the car warms up?
Wouldn't suspect a bad injector at 64K....
Check the simple stuff first (if you haven't already)
Derf
PS: How much oil do you burn?
Old Mar 7, 2006 | 11:19 PM
rchinny's Avatar
thanks.. it was the injector. changed it and all is fine...except wallet. It is a dealer item only so they hold all the cards...and my$159.00 just for the part
jenmetcalf5
Jan 3, 2018 08:12 AM
Dklemm
Mar 28, 2014 01:12 PM
amn0025
Nov 18, 2013 10:51 AM
Drock
Nov 30, 2009 10:08 PM
AztecDan
Engine & Internal
Jan 5, 2009 08:09 AM
