Coolant sensor
Old Jul 5, 2009 | 01:47 PM
motard1's Avatar
Default Coolant sensor
Is there one? WHere is it? My girlfriends car had some cooling issues. New thermostat and water pump fixed them. Now the coolant light is blinking. The temperature is normal,and its full of coolant. What gives?
It's a 1999 SL2.
Old Jul 5, 2009 | 05:06 PM
If the coolant light is blinking, it means that there is a problem with the sensor (or the wiring) that monitors the amount of coolant in the makeup tank.
Old Jul 5, 2009 | 11:21 PM
motard1's Avatar
So,where is the sensor? The tank is full. I hate cars.
Old Jul 6, 2009 | 06:35 AM
Sensor is near the bottom of the coolant reservoir. Since you've done prior work on the cooling system, I'll assume you know where that is. If you did a flush when you did your other work you may have crapped up the sensor.
birdy1
Apr 6, 2019 08:28 AM
sep25
Jul 24, 2011 10:56 AM
PdPuNOme
Oct 21, 2009 09:07 PM
jimmyslide
May 21, 2008 09:00 PM
jimmyslide
Apr 7, 2008 04:01 PM
