Coolant???
Old Aug 25, 2009 | 02:12 PM
tbarlow's Avatar
Default Coolant???
I have filled up the resuviar but it still shows that it needs water. it there a place on the top of the radiator to fill it up???
i have a 1999 Saturn SC1
Old Aug 26, 2009 | 08:37 PM
what shows it needs water ? the dash light?
with the engine cold, remove the reservoir cap and start the engine. Then get out and see if there are any air pockets being forced out of the cooling system. You'll know this to be the case if the reservoir level drops significantly. Turn off the engine after a minute and put the reservoir cap back on.
Re-start the car. If the dash light keeps flashing, the sensor at the bottom of the coolant reservoir is likely bad. You can remove the reservoir and try to clean it, but more often than not you need to replace the sensor.
rabobanks
Jul 7, 2008 09:10 AM
bmxgoof
Jul 27, 2006 02:02 AM
95Saturn
Jan 9, 2006 03:18 PM
LS2guy
Aug 22, 2005 03:17 PM
KELLYM
Jun 29, 2005 06:11 PM
