Compression Low #4 Cylinder
Old Feb 20, 2010 | 03:32 PM
Newtosaturn's Avatar
Default Compression Low #4 Cylinder
I have a 96 SL2 1.9DOHC. Have been having a problem with P0304 code. Tried plugs, wires, coil packs, fuel filter, switching injectors around. Checked compression today and here is what i have. #1 185 #2 200 #3 185 #4 47!!!. So the question is, do i have bad rings, valves, head gasket. The car has 113,000 miles on it. I did put a few squirts of oil in #4 but it did not help compression. It uses oil, but none of the plugs seemed black, and there is what appears to be alot of oil on the bell housing like its would be coming from that end of the head by #4 cylinder. I have no loss of anti freeze, nothing in the oil. My problem is, if its the rings i think i will just get rid of the car, but if its just say a head gasket or valves i may be interested in fixing it. Any help would be greatly appreciated to point me in the right direction.
Old Feb 23, 2010 | 06:06 AM
Well, you did your "squirt thingy" into the cylinder and retested the compression with no improvement (apparently). That would suggest that rings are not your problem. Like John Wayne said in 'Flying Leathernecks' -- "Looks like you're going to have to go in, Pilgrim".
tomc
Jan 3, 2015 10:46 PM
ngrome
Mar 21, 2011 09:16 PM
jttalg28
May 12, 2010 10:38 AM
Devefaux
Engine & Internal
Mar 16, 2009 07:11 PM
betinaq
Jun 13, 2005 10:19 AM
