a/c SL2 Problem
Old Aug 17, 2007 | 04:30 PM
jasontut's Avatar
My 93 SL2's a/c has not been working. I hada belt start to shredand I believeit cut one of the wires coming out of the alternator. I'm pretty sure this has cut thepower to my a/c. In these pictures you can see the harness and green wire that has beencut:
[img]uploads/jasontut/saturn2.jpg[/img]
[img]uploads/jasontut/saturn1.jpg[/img]
Does anyone know where this wire should lead or have any advice on how to fix it? Thanks guys.
Old Aug 17, 2007 | 05:46 PM
ducky's Avatar
I believe that wire is the main power wire to the compressor clutch. Look closely at the connector and disconnect it if necessary to examine the wire color. If its the same green wire you may be able to trace where it comes and goes to find the two ends that were once one piece and cut by the belt. If you can find the two ends you'll be able to solder them for the best electrical connection or trim away 1/2 inch of insulation on both ends to twist together tightly and wrap tightly with electrical tape several times past one inch on both sides of the twisted wires to ensure it won't unravel in the future from heat and cold.
