Buying a ’’97sl1
Old Nov 10, 2008 | 04:21 PM
richp's Avatar
Hi, I am in the process of picking up a 97 sl1 with approx 107,000 miles. The car has sat idle for most of this year. Aside from fluid changes and tune-up items, is there anything I need to look for,or be aware of? How about repair manuals? Haynes,Chiltons,or something else? Online parts?Any info would be appreciated. Thanks. Rich
Old Dec 7, 2008 | 01:35 PM
qwiksl1's Avatar
the best repair manual is actually the dealer/factory manual because its year/model specific change the oil, tranny fluid, spark plugs and wires, intake filter, and if it sat for a long time(more than six months) fill the tank once with premium fuel to clear the crud out of the fuel system it wont hurt it the only reason i said once is the car actually gets addicted to premium if its too expensive i would just do it the 1 time. hope this helps. if its a manual transmission saturnsare actually pretty fun to drive! let me know if i forgot something
Old Dec 8, 2008 | 04:36 PM
Low Saturn's Avatar
Should also do a couple top end cleanings with Seafoam, MMO or GM Top End Cleaner. After sitting that long the pol control rings are most likely stuck and dried up. This will lead to massive oil burning. Should be fine after the cleanings though.
john doe
Dec 28, 2010 07:25 PM
turbochargedv8
Oct 13, 2009 06:37 PM
Drag Limited
Nov 14, 2008 07:46 PM
natoe33
Aug 27, 2006 01:54 PM
Dead GP
May 1, 2006 11:53 AM
