Belt Drive pulley
Old Jun 17, 2012 | 12:44 AM
jchubb01's Avatar
Default Belt Drive pulley
So my belt drive pulley bearings blew out, the threads on the bolt and the hole are fine, the bearings are shot. Going out to get a new drive pulley monday and change it, how hard are these done?
1995 Saturn SlL 1.9 SOHC w/ ac
Old Jun 17, 2012 | 07:55 AM
I'm not sure what you mean by "belt drive pulley". There are several pulleys on the system including crankshaft pulley, alternator pulley, alternator pulley, power steering pulley and belt tensioner pulley. Which one are you referring to? Bottom line is which pulley and your mechanical abilities. I'd say an hour or less for those of us who've been working on our own stuff for years, but I don't know about yours.
Old Jun 17, 2012 | 09:22 AM
be carfeful with pulley size with the aftermarket belt tensioner or idler ones --
I THINK I remember reading somewhere that some aftermarket ones are not quite the right size
Or I'm hallucinating again
Old Jun 17, 2012 | 09:52 AM
No Derf, you're not hallucinating -- I've seen the same thing. I finally have gotten to the point where I replace the entire assembly. Costs more, but the "less headaches" makes it a no-brainer in my book
Old Jun 17, 2012 | 03:39 PM
jchubb01's Avatar
Oreillys has it labeled as a belt drive pulley. I figured that was what it was called. Sorry.
I will definitely check the size of the pulley when I go buy the new one as I still have the old one.
Old Jun 19, 2012 | 09:16 PM
Well if the belt doesn't fit when your done .. return the part and get it from GM.
QuietFlight
Nov 18, 2017 12:42 AM
cparsels
Oct 6, 2015 11:25 PM
dbhost
Dec 6, 2011 04:03 PM
satty_kingsb
May 8, 2008 02:07 PM
mfunk49
Feb 1, 2007 06:24 PM
