Ignition cylinder help
Replacing the ignition cylinder. Removed old one withouttip much trouble. Went to install new one and the keyed pin off the ignition switch that mates into the rear of the cylinder seems to be rotated 180 degrees and won't allow the cylinder to install completely. What am i missing here?
Clearly you are frustrated with us, but since we have not personally encountered said problem previously, it'd be a lot easier if you could post a pic of the situation. We can't see or touch your car.
04-24-2013 08:49 AM
