99 SC1 High Idle Problem
Old Feb 15, 2013 | 06:18 PM
99 SC1 Silver's Avatar
Went out ro test the gasket for a leak. Idle was about 900rpm, spray didn't seem to make a difference. Sometimes the idle does get above 1000 when warm. I'll check it then. I've got a new TB gasket. Could that be worth a shot?
Old Feb 16, 2013 | 10:56 AM
ReTB (it's spotless) and installed new TB gasket. Still the same problem. Took the car to my mechanic and he checked it out through the OBC port. He said everything looks good and thinks it is the PCM. I unplugged and reconnected the PCM (thinking maybe a corroded terminal- all terminals were OK visually)and reset the PCM. No change. I'll get a PCM from the junkyard tomorrow and give it a try.
Old Feb 18, 2013 | 04:05 PM
DOHC96's Avatar
Default pcm
Lets us know, also how much does one of those PCM run on price?
Old Feb 19, 2013 | 12:58 PM
You can price one at
www.saturnparts.net
www.saturnparts.com
or any number of other places, such as NAPA online.
Old Feb 19, 2013 | 06:42 PM
I picked up a PCM for $35 at a salvage yard (making sure the numbers matched up). Had my mechanic put it in once I realized how hard it would be to get to the mounting nut much less get it off (they had to remove the dash top to get to it). It basically took care of the problem. I've got the famous intake manifold leak at cylinder 1 so it idles at around 1100 rpm. Other than that, as I continue to rack up ignition cycles it runs better and better.
Old Feb 19, 2013 | 06:43 PM
One more thing, it seems that for 99 the SOHC and DOHC PCMs are the same unit.
Old Feb 20, 2013 | 05:44 PM
Try what I did. Maybe you can get your mechanic to read the OBD codes and save you some of those steps. Let me know how it turns out. The sensors are easy to change. The PCM is a PITA.
Old Feb 28, 2013 | 12:33 AM
DOHC96's Avatar
Default soooo?
How did the changing pcm work out for you.
Old Feb 28, 2013 | 06:47 PM
The PCM helped a lot but I still have the famous intake manifold gasket leak in cylinder 1. Working on that one now.
Heaton4
Oct 15, 2013 09:54 PM
jrg89
Jun 30, 2013 09:34 PM
cloudsplitter8
Aug 24, 2012 07:47 PM
99saturnsc1
Dec 8, 2006 12:25 AM
x86guru
Jun 17, 2006 04:24 PM
