99 SC1 High Idle Problem
Old Feb 14, 2013 | 06:13 PM
99 SC1 Silver's Avatar
Default 99 SC1 High Idle Problem
I've got a 99 SC1 SOHC. Here's my problem. At startup the idle goes to 2000 RPM then eases down. When starting forward at about 2MPH the idle jumps to 1700-1800 RPM and stays there until I come to a stop, at which time it comes back down. I've changed the IAC valve, TPS sensor, ECT sensor, and the MAP sensor. Still the problem persists. Any thoughts?
Old Feb 14, 2013 | 06:19 PM
I'm going to change the throttle body gasket tomorrow as a precaution.
Old Feb 14, 2013 | 06:22 PM
Clean the TB while you have if off.
Old Feb 14, 2013 | 06:24 PM
Done that but not a very complete job. I'll finish it while I have the throttle body off.
Old Feb 14, 2013 | 06:30 PM
Here's a little more info. The problem was initially intermittent and I could fix it by stopping the car, shutting the engine off, and restarting it. Is it possible that my computer has gone bad?
Old Feb 14, 2013 | 08:11 PM
1-Maybe stop in the new member area and introduce yourself
2-Add you first name, location, yr and model to your signature
3-2 can be done in the user CP
4-Read this https://www.saturnforum.com/forum/general-tech-help-13/etcs-its-connnector-6417/
Old Feb 14, 2013 | 10:16 PM
I'm new here. How do I get to the new member area?
Old Feb 14, 2013 | 10:19 PM
Never mind, I just figured it out.
Old Feb 15, 2013 | 05:07 PM
keith's Avatar
After warmup, check the idle speed in neutral or park. If it is above 1000 rpm and won't settle down lower, then check for a vacuum leak around the #1 cylinder intake manifold gasket. The outer top corner is not well supported and sometimes gets sucked in there. spray something in this area and if the idle changes, then the gasket is leaking.
Old Feb 15, 2013 | 05:17 PM
DOHC96's Avatar
Default problem
So 99 what was the problem can you feel us in on it?
