99 Saturn SL Camshaft Position Sensor/O2 sensor
Old Jun 22, 2011 | 11:28 AM
sep25's Avatar
Question 99 Saturn SL Camshaft Position Sensor/O2 sensor
I took my car(99 saturn sl) for emissions at meineke. I knew i wouldnt pass emissions because my check engine light was on but i wanted to find out why anyway so i just did it. here on the paperwork it says diagnostic trouble codes: P0133:O2 Sensor Circuit Slow Response Bank 1 Sensor 1, P0341:Camshaft Position Sensor "A" Circuit Range/Performance Bank 1 or Single Sensor. To me that was written in french so they basically told me that i need a camshaft position sensor and an O2 sensor. they also told me i need a valve cover gasket and a new catylitic converter. the Saturn place told me that i dont have a cam sensor. i have no idea where to start on my car. sometimes my car doesnt want to start and i have to wait 10 min to a couple hours before it will start again and other times it will start right away. if anyone has any suggestions it will be greatly appreciated.
Old Jun 23, 2011 | 10:51 AM
Well, obviously I'm not where you are, but if it were my car, here's what I'd do, and the order in which I'd do 'em:
1) Replace the forward (upper) O2 sensor
2) Replace the Crankshaft Postion Sensor (CPS)
At this point in time, I'd reset the computer on the car, and drive it for a couple of days to see if the diagnostic trouble codes come back. If not, then I drive it another couple of days, and then take it back for your emissions test.
If you are still having problems getting your car to start, I'd look into replacing the Engine Coolant Temperature Sensor (ECTS) and it's associated electrical connector. This sensor controls the air/fuel mixture on the engine, and can make it a real "bear" to start sometimes.
As far as the catalytic converter, I'd hold off until this other work was accomplished. True, catalytics can go bad, but I've seen a bunch of good units replaced, and unless I was dead sure the converter had failed, I'd take a "wait and see" position. Good luck ...
Old Jun 23, 2011 | 11:20 AM
scotterichmond's Avatar
Good sound advice, ...... and all things that are common to go bad ........ sometime down the road.
Old Jun 24, 2011 | 10:47 AM
sep25's Avatar
Thumbs up Good Look
Thanks for the advice....I am going to see what happens and I will be back.
Old Jul 24, 2011 | 10:28 AM
saturnchix's Avatar
Default Sep 25, jr member
hey...was wondering what you did to fix your problem??? ect or cps did u change either one?
i have 70k 98 sl2 and havin ur same problems......dont know which one to change??
let us know thanks guys
Old Jul 24, 2011 | 10:56 AM
definitely replace the front 02 sensor mounted in exhaust manifold.
replace the ects as indicated above
cam codes are usually an indication that something is amiss in the ignition system.
I'd start simple with wires and plugs
97sc1
Engine & Internal
Sep 20, 2025 02:42 PM
dabatman99
Aug 13, 2023 07:16 AM
SaturnAndy
Saturn Aura
May 11, 2015 12:48 PM
sl2noob
Feb 23, 2011 05:39 PM
dceyes
May 15, 2009 07:51 PM
