99 Saturn SL camshaft position "A"
Old Nov 15, 2008 | 06:59 PM
dabatman99's Avatar
On my code reader, the code camshaft position "A" comes up. Anybody know what it means?
Old Nov 15, 2008 | 09:58 PM
Low Saturn's Avatar
What is the exact code? Saturn S-Seires dont have cam position sensors.
Old Nov 16, 2008 | 08:05 AM
dabatman99's Avatar
That''s what I thought too... I didn''t write down the code, but if it pops back up, i''ll check it again. This is not the first time this code comes up. The car belongs to my girlfriend, and she couldn''t get it running for a few days. It would turn over and kick a bit (almost like it was firing on 2 cylinders). Then last night her friend tried it and played with the throttle apparently and got it going. The car was running fine when she shut it offa few days ago, then this happened. I''m not too familiar with these cars, but I did go out and buy a Haynes manual (just like every other Haynes manual...not enough detail). Like I said theis code has popped up before, but the car never skipped a beat! I told her that maybe she needs new plugs/wires, new fuel/air filters etc. Apparently she''s never changed them in 5 years she''s owned the car...what u think about that???
Old Nov 16, 2008 | 09:59 AM
Low Saturn's Avatar
If you get the "cam position sensor" code. Then check for bad plugs, wires, oil in the spark plug wells (due to a leaking valve cover), and corrosion on the coil pack towers.
The PCM uses crank position and ignition timeing of cylinder #4 to determine cam position.
Old Aug 13, 2023 | 05:26 AM
genelor's Avatar
Thanks for that information
Old Aug 13, 2023 | 07:16 AM
genelor, that thread is 14 years old. I'm happy it helped you. If you're having problems with your S series Saturn, tell us what's going on. Maybe we can help. Derf is our resident S series guru and if HE isn't able to help you, then I'm not sure any of the rest of us can.
97sc1
Engine & Internal
Sep 20, 2025 02:42 PM
sep25
Jul 24, 2011 10:56 AM
ChurchBuilder
Jul 20, 2007 05:18 AM
Genocide
Apr 17, 2006 02:15 AM
mpk4580
Jan 25, 2006 08:09 AM
