98sl changing oil
Old Nov 14, 2009 | 09:25 PM
turbochargedv8's Avatar
Default 98sl changing oil
it was a bitch changing the oil on my 98 sl i used a mobil1 oil filter and valvaline oil.
the filter was in an odd place and i had to jack both sides up with stands and reused the rubber drain plug seal.
am i better off doing that work or trusting these 5 minute oil change places next time.
Old Nov 14, 2009 | 11:32 PM
saturnsdn's Avatar
the easiest way i've found is remove the splash plate next to the filter and just cut the wheels towards the driver side for easy access to the filter otherwise yea its a bit of a pain but still do able
Old Nov 15, 2009 | 07:18 AM
you're better off replacing the rubber drain plug seal.....
s10blazer99
Feb 26, 2011 03:35 PM
turbochargedv8
Dec 26, 2009 11:17 AM
turbochargedv8
Dec 9, 2009 08:08 AM
ASKBCG
Oct 20, 2007 08:34 PM
X-Vert
Mar 3, 2007 09:48 PM
