98 SL1 hard start / rough idle fix (also 91-01 S-series)
Old Jul 15, 2010 | 08:26 PM
NRA Steve's Avatar
Default 98 SL1 hard start / rough idle fix (also 91-01 S-series)
a cracked engine coolant temp. sensor was causing my problem @ 137,000 miles . service bulletin#01-T-07 (Jan.7 , 2003 ) describes
the problem of hard start , erratic idle , etc. and recommends a new
design sensor P/N 21025106 be installed on 1991 -2001 Saturn S-series
vehicles . I put teflon pipe dope on the threads of the new sensor and
removed the old sensor with a 13 mm deep socket . I quickly stuck my
finger over the hole to stop the coolant from draining and put the socket
on the new sensor and quickly installed it . only lost a small amount of
coolant . plugged the wiring connection back up and it now runs good
again . the old sensor had a visible crack . I hope this helps others keep
their cars running. COST OF THE NEW SENSOR $20.77 @ GM DEALER
Old Jul 15, 2010 | 10:53 PM
Thanks for the head's-up on the Service Bulletin and the part no. change for the older "S" vehicles
baconman1982
Dec 9, 2014 07:09 AM
Bobbed06
Feb 22, 2012 10:41 AM
sl bill
Jun 26, 2011 08:01 PM
Joe Lukaitis
Apr 28, 2008 03:42 PM
firefighter
Nov 8, 2007 04:27 PM
