98 SL Running Rich???
Old May 28, 2009 | 08:09 PM
saturmham's Avatar
Cool 98 SL Running Rich???
Here is a problem I have not been able to fix. My 98 SL is running rich on Starts only. Usually have to hold the throttle open to get it to start then after 30 seconds it idles normal. The MAP sensor was replaced, injectors tested fine, and fuel pump consistantly runs the correct pressure. Any suggestions??
Old May 28, 2009 | 10:31 PM
have you replaced ECTS with brass style replacement?
Old May 29, 2009 | 07:53 AM
saturmham's Avatar
I have not. How would this affect the fuel mixture?
Old May 29, 2009 | 10:45 AM
Time for "chalk talk" ....
Engine Coolant Temperature Sensor - (ECTS) monitors the temperature of water exiting the engine. Its signal is sent to the Powertrain control Module - (PCM) where the computer reads the signal, and adjusts the fuel mixture ratio for maximum economy and efficiency. If the sensor is open, the PCM will think the engine is very cold, and adjust the settings accordingly. If the sensor is shorted, the PCM will think the engine is very hot, and adjust the settings that direction.
Use only brass-tipped OEM replacements for reliability. Replace the electrical connector on the wires at the same time. Use Teflon tape on the sensor threads to make the job easier, and work only on a cold engine, to avoid scalds/burns.
Material costs will be about $40usd ($15 for the sensor, and $25 for the connector).
rm2011
May 10, 2013 12:24 PM
Claplume
Apr 23, 2013 12:37 PM
john33
Sep 25, 2010 06:27 PM
tfg11199
Oct 17, 2009 09:44 PM
jillowolf
Jan 14, 2006 08:51 AM
