'97 SL2 Exhaust Manifold Integrated Catalytic Converter Replacement
Old Jun 5, 2018 | 03:06 PM
Lea Fairbanks's Avatar
Default '97 SL2 Exhaust Manifold Integrated Catalytic Converter Replacement
Hi all,
Long time reader first time poster. This form is really helpful!
I have a 97 Saturn SL2 and the exhaust manifold integrated catalytic converter is clogged. I took it to a shop and they diagnosed it then turned me away - said it's not fixable because they can't get a replacement part.
Do I have any options here? I've searched online and I can't find a replacement either. Nothing looks the same and none of the recommended parts actually list the 97 year as a compatible car. Any fix I make would have to be legal since it's up for emissions this month.
Other than this, the car runs great! (with the o2 sensor out it runs pretty fine now!) I have taken great care of it and got it up to 280k miles. New starter and battery last December. Rebuilt transmission valve body last fall. Was really gunning for 300k!
Thanks for your advice!
Lea
Old Jun 5, 2018 | 10:23 PM
I suspect you have a California emissions car, we might need some information off the underhood sticker.
Old Jun 5, 2018 | 10:45 PM
I looked at the California Air Resources Board site. There are exemptions available for some aftermarket cat converters. You may be able to replace the main converter and gut the manifold converter and still remain legal. Start inquiring with C.A.R.B. Officials on how to make your car legal now. Do not wait for your test date. There are often exemptions if the repair cost is over a certain amount of money. I do not see any California exhaust system parts on Rock Auto or Napa sites.
Old Jun 6, 2018 | 05:16 AM
https://www.trademotion.com/parts/1996/Saturn/SL2/Base/?siteid=214568&vehicleid=175818&section=EXHAUST%20 SYSTEM
Supposedly this GM 21006802 / Exhaust ManifoldSATURN; DOHC; CALIFORNIA; LEV.
Costs a pretty penny.
Old Jun 6, 2018 | 03:30 PM
Thanks for the info. I'm not willing to spend $800+ fixing it unfortunately.
Here's some pics of the sticker and exhaust manifold.
https://i.imgur.com/2UTVhwD.png
https://i.imgur.com/RQPUd18.png
FYI I am registered in Utah, I talked to a representative of CARB and she turned me away. I found the guy in Utah and he's calling around to see what we can do to get me legal again.
I'll keep you posted.... Thanks!
Old Jun 6, 2018 | 08:54 PM
Since you are in Utah there is a much better chance to pass smog as a Federal emission car. Do independant garages do your smog tests or is it all state offices? The federal cars only have one cat converter downstream. It all depends where the downstream O2 sensor is in the exhaust system. If the sensor is past the downstream cat then the shop could gut the manifold cat and the sensors would still work properly. I would ask the Utah smog guys what will it take to make it legal. Is all of Utah smog tested or just the greater Salt Lake area? You may have to sell it out of the smog tested area, disclose that it will not smog.
mitchcar
Saturn L300
Sep 4, 2019 07:09 PM
Timtheelite2025
Mar 21, 2019 08:37 AM
01saturnl200
Jun 18, 2018 11:34 PM
cadman33619
Mar 9, 2013 09:28 AM
hdloride69
Aug 9, 2011 09:24 PM
