97 SL1 starting problems
Old Jul 10, 2008 | 05:58 AM
jpmctd's Avatar
97 SL1 starts hard sometimes. The engine cranks and doesn''t turn over right away. This happens occasionally, not all the time. Just bought the car used, has 96K miles. Does anyone know what this could be?
Old Jul 11, 2008 | 11:10 AM
TheEngineer's Avatar
could be anything. I would start with the general maintenance stuff...air filter, fuel filter, spark plugs
Old Jul 13, 2008 | 12:19 PM
IVI4ssacre's Avatar
97 s series had problems with the fuel pump.
Old Jul 13, 2008 | 02:58 PM
jpmctd
Quick question here ... does the hard start condition happen only when the fuel tank level is 1/4 tank or less?
Old Jul 13, 2008 | 03:13 PM
95jive's Avatar
yeah i would imagine it could be the fuel pump, the pump relies on the gasoline to cool it off.
Old Aug 19, 2008 | 06:45 AM
jpmctd's Avatar
Still working on this problem. Alternator, battery, spark plugs, starter check out fine. Seems to happen only when the tank is filled. Subsides after that, and happens again at the next fill up?????
Old Aug 19, 2008 | 09:01 AM
Low Saturn's Avatar
Are you getting any warning lights?
Could also be the pressure regulator or the EVAP system.
Old Aug 19, 2008 | 09:57 AM
jpmctd's Avatar
No warning lights. Happened again yesterday when i filled the tank. Is starting to work ok again today.
Old Aug 19, 2008 | 10:18 AM
Low Saturn's Avatar
How far do you fill the tank? Until it clicks. Or does it click then you put in more?
Old Aug 19, 2008 | 10:47 AM
jpmctd's Avatar
Usually when it clicks (stops filling) I give it one more pump and it clicks again and I stop.
