97 SC2 1.9 DOHC Stumbles when hot
Old Mar 11, 2008 | 08:16 PM
camaronut's Avatar
Just bought a 97 SC2 coupe with 1.9L DOHC, 80K mikes with a 5 speed
The car runs great when its cold, but when it warms-up, it hesitates when applying any pedal pressure. The car doesn't quit or anything, it just stumbles and goes on, until you change gears and apply the gas again.
When cruising, it wil do the same when applying the gas....
Any suggestions / cures???
I would really appreciate it!!!!
ThanksEdited by: sw2cam
Old Mar 12, 2008 | 10:35 AM
Low Saturn's Avatar
Classic signs of a bad temperature sensor. Check to see if its the original plastic tipped one. These usually crack. You'll need a new brass tipped one. OEM ones seem to be more accurate and can be found for less than $20.
Old Mar 12, 2008 | 11:05 AM
camaronut's Avatar
Mike,
Thanks...I'll get one tonight from Autozone.
Where exactly is it on the 97 1.9L DOHC? I think I saw it under the thermostat housing.....Edited by: sw2cam
Old Mar 14, 2008 | 05:11 PM
Low Saturn's Avatar
Nope, no sensors there. Its located on the drivers side of the head, below the EGR valve. Inspect the connector. Those tend to corrode from a faulty sensor leaking coolant on them.
Old Mar 16, 2008 | 09:32 AM
camaronut's Avatar
Replaced the coolant sensor....with no change....still stumbles...but, the temp gauge seems to read at mid level now.....it use to read way lower.
When I looked at the original sensor....it was the plastic one, and was cracked.
I'll try the TPS next....
If anyone has any other ideas..I would appreciate it!!!
Thanks
Old Mar 16, 2008 | 11:49 AM
Low Saturn's Avatar
How was the condition of the connector that attaches to the coolant sensor?
Old Mar 16, 2008 | 09:34 PM
camaronut's Avatar
It looked OK to me.....
I didn't see any coolant on the connector....
The contacts looked OK...
To make sure, can I buy one of these connectors at a Saturn dealership, or can I go to a local auto place like Autozone....
I changed the TPS....nothing...still stumbles when hot.
Old Mar 16, 2008 | 11:40 PM
sl1driver's Avatar
Had a similar problem on my 94 SL1 w/automatic about drove me nuts mine had the old coolant temp sensor on it which I replaced but what finally fixed it for good was an egr valve(the spring was weak I guess I tried cleaning it but it wasn't that dirty it didn't help)removed and replaced the EGR valve and the car is running great again. Good Luck.
Bryan
Old Mar 17, 2008 | 11:11 AM
camaronut's Avatar
I did get another EGR from a junk-yard last Saturday, and used it also....didn't work...
But I did notice that the spring was real "loose" on both my original and junk yard unit.
I'm going to try blocking the EGR valve tonight, and see if that cures it....
If it does....well it's gonna hurt $$$$$
They're about $120 from Autozone....
Old Mar 17, 2008 | 08:47 PM
camaronut's Avatar
Blocked the EGR valve....still stumbles......
Don't know what's next [img]smileys/smiley7.gif[/img]
Any help??
