| uncljohn |
Jul 20, 2011 01:20 AM |
A P0702 is a transmission electrical error code and is not generally something that would affect the operation of the engine.
http://www.obd-codes.com/trouble_codes/
Having fuel to the rail and having it at the right pressure or something that approaches the right pressure is a whole nother subject. Is there any other information you can give? Has the car ever run if so is this some kind of a new problem?
If you are just starting this trouble shooting it might be a basic problem such as a vacuum leak at the intake manifold leaning it way out or an extremely dirty throttle body which might be able to be cleaned with a spray cleaner. Have you tried using starter fluid to help start the car? If it fires right up and then dies, that could mean the fuel at the rail is not getting by the injectors or a big vacuum leak. Can you measure fuel pressure? Have you checked for spark intensity?
It is a bit hard to guess at with the amount of information given at this time.
